Scorpa Tys 125 F , Steering Lock & Choke Advice !
dayvee
Hi I have just bought a Scorpa TYS 125 F which has just been used by the previous owner for "pottering" about , I have stripped the lights off it to day and removed the speedo and bracket and steering lock etc to start riding trials.
Has anyone else done this and did you remove the steering lock bracket which is welded to the steering head ? and where do you mount the choke lever if you re move the speedo bracket ?
any advice or tips would be appreciated thanks Dave
Edited by dayvee
My steering lock had been removed by the previous owner and I modified the choke with a shorter cable. Look at Birkett Motosport website for further mod's.
Has the bracket been removed from the head stock ? and where is the new choke mounted cheers
I have made a "joggled " bracket off the rear coil mounting bolt and re routed the choke cable from the front of the bike round and under the carb , seems to work fine , and gets rid of that horrible big bracket at the front of the bike .
