duckwizard Posted December 29, 2004 Report Share Posted December 29, 2004 Did Bultaco make 38 mm forks. Betor type. Around 1983. I need details of the damper assembly etc Quote Link to comment Share on other sites More sharing options...
woody Posted December 30, 2004 Report Share Posted December 30, 2004 As far as I know, Sherpas and Pursangs only had 35mm forks, the Sherpa forks being pretty much the same as Ossa, other than the leading axle. To clarify you should contact Dave Renham at Bultaco UK as he is the leading UK Bulto specialist http://www.bultacouk.com Quote Link to comment Share on other sites More sharing options...
martinm Posted December 30, 2004 Report Share Posted December 30, 2004 SWM Jumbo's used 38mm Betor forks on the 1984 model......maybe a set of those has ended up on your Bultaco? Martin Quote Link to comment Share on other sites More sharing options...
