the addict Posted February 8, 2010 Report Share Posted February 8, 2010 Mate of mines got a 2010 Raga 300 and in need of a rear wheel for it as a spare, did here the 4rt wheel may fit? does anyone know? Many thanks Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted February 8, 2010 Report Share Posted February 8, 2010 it doesn't, closer to a sherco. from memory the disc to sprocket distance is wrong? Quote Link to comment Share on other sites More sharing options...
the addict Posted February 8, 2010 Author Report Share Posted February 8, 2010 Thanks Andrew, will see if we can offer a Sherco one up to it then Quote Link to comment Share on other sites More sharing options...
benz19 Posted February 8, 2010 Report Share Posted February 8, 2010 it doesn't, closer to a sherco.from memory the disc to sprocket distance is wrong? Montesa whell does fit,ive had one in various Gassers over last 12 months. Just need different spacers. I had mine made,ill measure then tomo and give you the details! Benz Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted February 8, 2010 Report Share Posted February 8, 2010 Surprised at that. Simply measure the sprocket to disc and if it matches then its spacers. Pretty sure Subira did a list on here a while back. sEARCH THE FORUMS FOR THAT IT SHOULD TURN UP . jUST BE SURE TO CHECK OFF SET TO BE 100%. Quote Link to comment Share on other sites More sharing options...
the addict Posted February 9, 2010 Author Report Share Posted February 9, 2010 Mate stuck the 4rt wheel in his Gasser today and it goes no probs, slightly to the left but 30 mins on the lathe will make the spacers up to correct it Quote Link to comment Share on other sites More sharing options...
benz19 Posted February 9, 2010 Report Share Posted February 9, 2010 Mate stuck the 4rt wheel in his Gasser today and it goes no probs, slightly to the left but 30 mins on the lathe will make the spacers up to correct it JOB DONE!!! Quote Link to comment Share on other sites More sharing options...
mostar Posted February 16, 2010 Report Share Posted February 16, 2010 hi Can any one please tell me what size the spacers have to be to make a mont wheel fit a GG. Thanks Quote Link to comment Share on other sites More sharing options...
