nevilletanner Posted February 9, 2010 Report Share Posted February 9, 2010 Near the petrol tank there is a digital clock / odometer / speedo, this was not working so i took it out and replaced the battery that fits inside it. it now displays ok except it does not actually to anything ( ie speedo stays at 0 ) is it meant to connect to something (on the back of the clock there are two solder points with nothing connected to it) also i have found a wire that goes to the rear brake caliper, i am assuming this is some kind of sensor for the speedo but i cannot figure out where it goes or what it connects to. any idears ? many Thanks. Quote Link to comment Share on other sites More sharing options...
dan williams Posted February 9, 2010 Report Share Posted February 9, 2010 Yeah it went to a wheel sensor. These things never worked well as they were made for bicycles and the sensor wires weren't shielded well enough to prevent the ignition from messing with the signal. Quote Link to comment Share on other sites More sharing options...
