ausy300pro Posted February 14, 2010 Report Share Posted February 14, 2010 Does anyone know of an alternative kickstart for the 175, the one on my bike is worn and rather than mess about welding and bushing etc or replacement with a new standard kickstart at about Quote Link to comment Share on other sites More sharing options...
stork955 Posted February 15, 2010 Report Share Posted February 15, 2010 Gday, on mine I used a standard style kickstart that had the correct spline and cold bent it in the press. Worked a treat. Might be an option for you. Cheers, Stork Quote Link to comment Share on other sites More sharing options...
andy.t Posted February 15, 2010 Report Share Posted February 15, 2010 As far as I know one of the older type GASGAS kick starts will fit and they do look nice, also one of the RD350 ( I think) will fit but they are a bit on the long side. The other problem is that the GASGAS ones do fetch good money, you can get a RD one easy enough off Ebay. Quote Link to comment Share on other sites More sharing options...
ausy300pro Posted February 16, 2010 Author Report Share Posted February 16, 2010 Thanks for replies, Stork 955 you said you used a standard kickstart, what was it from ? Andy T thanks for that, RD kickstart does look suditable and with being a metal one I can bend and shorten it if needs be, looks like I will be ebaying for one of those, Cheers to both Quote Link to comment Share on other sites More sharing options...
stork955 Posted February 16, 2010 Report Share Posted February 16, 2010 Gday, I have no idea what mine came off, I would imagine that it was from a DT or similar. Cheers, Stork. Quote Link to comment Share on other sites More sharing options...
subanator Posted February 17, 2010 Report Share Posted February 17, 2010 I tried the RD one but not happy with the outcome. Firstly the straight length of the RD on interferes with the exhaust and your leg when riding, very off putting Secondly the pivot shaft is on the crankcase side, and needs to be angled away putting the lever to far back. So I heat bent mine to that of the TY, and ended up with it short in kick length to the TY one. The design of the RD one is better than the TY on the pivot being better and stronger than the TY's design. In the end I need an new TY one as the output shaft pinion was flogged out, so a new kicker with the assembly was my best option. Cost was weighed up to piece of mind due to holing the clutch cover previously with the old kickstart lever over-returning due to the stuffed pinion. Quote Link to comment Share on other sites More sharing options...
ty_steve Posted May 17, 2010 Report Share Posted May 17, 2010 Hi Ausy300pro As I'm in the same boat that you are/were I was wondering if you came up with any alternatives or just ended up shoveling out the cash for a new kick-start? Thanks, Steve Quote Link to comment Share on other sites More sharing options...
