not ron Posted February 15, 2010 Report Share Posted February 15, 2010 I have ridden my TLR250, in about 10 times a year since 1996 and generally it is reliable but there is one problem. Regularly every 10 to 20 trials the rear wheel bearings need replacement. I am carefull not to over tension the chain and have tried both Honda original equipment and after-market bearings. The rear wheel is the standard TLR 250 one without any cush-drive. I wondered if anyone else had the same problem and had found any way to improve the situation. Quote Link to comment Share on other sites More sharing options...
stork955 Posted February 15, 2010 Report Share Posted February 15, 2010 Gday, does it have the correct spacer between the bearings? Or indeed any spacer? Cheers, Stork Quote Link to comment Share on other sites More sharing options...
