Ty250a Wheel Bearings
bengtphorqs
Working on the refurb of my '74 TY250A and it's time to address the wheel bearings. The owners manual makes reference to an "L" shaped tool inserted into the spacer sleeve and then whack it out with a hammer. Sounds like a crude method to me, but what the heck. I tried using an Allen wrench and some PB Blaster but no joy. Any suggestions on how to remove the wheel bearings? What kind of tool works?
The spacer between the bearings can usually be moved sideways enough to get a 3/8"steel drift or punch to contact the inner race of the bearing on the far side to where you are.
If you warm up the hub the bearing will come out without taking any aluminium with it.
The special Yamaha tool does work but an allen key has a radius at its bend that prevents it transmitting enough force to the spacer. You can replicate the Yamaha tool by fitting a piece of 4mm round steel into a cross hole in a piece of 8mm round steel.
There are many ways to remove wheel bearings but by far the easiest is to use the right tool. Have a look at my blog and locate the article "How to .. Wheel Bearings" published in Feb 2008 and it will give you a detailed guide with lots of reference pictures to help along the way.
Tony
Tony, that's an OUTSTANDING discourse on the wheel bearing removal. Just what I was looking for. I came across this tool review in my search. http://www.4strokes.com/reviews/pitposse/wbremover/ This set by Pit Posse looks like the one you are using. Also, I save your blog to my favorites because I think I'll find some more goodies. Thanks!
