Gear Shift On The Sherco 3.2
fulmine
What problem are you having exactly?
Shercos have a groove on the gearchange shaft where the pawl is welded on which allows the shaft to twist or break rather than cause damage to the gearbox internals, if you're struggling to select gears have a look at how close the lever gets to the bashplate when moving downwards
If thats the problem its a easy fix, order a new shaft(about 40gbp) & gasket then pull the clutch off & change shaft. All very self explanatory when you do it
Any problem other than that & you'll need to explain the symptoms better
I'm watching the ads Sherco 3.2 and have already used two owners who tell me they have replaced one of the gear because of the second crack, the other had changed gears shift well without specifying which ones and why.
So I began to suspect that the change of the Sherco 3.2 might have inherent problems.
Thans all.
