stephen1967 Posted March 6, 2010 Report Share Posted March 6, 2010 Hi , I have a Beta Rev 3 250cc (2005 ).Recently I took the carb off to clean it (not an easy job ! ). When I have put it back together and started the bike it over revs,tried to turn the tick -over down with the two adjustment screws but it still over revs. Anybody know why my bike is doing this ?.Hopefully there is a simple solution but I don`t seem to be able to work it out myself. Your help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
earthmover Posted March 6, 2010 Report Share Posted March 6, 2010 Have you routed the throttle cable correctly? Did you tighten the elbow on top of the carb? Is the cable seated in the elbow properly? HTH Mark Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 6, 2010 Report Share Posted March 6, 2010 With the engine off, when you open the throttle and let it go can you hear it hitting the stop ? If not investigate as above. Quote Link to comment Share on other sites More sharing options...
munch Posted March 6, 2010 Report Share Posted March 6, 2010 after refit, always check the slide is fully closed, hold your finger on the carb and twist throttle fully open and let go ! you should feel a metallic clunk on you finger, telling you the slide is closing. no racing engine speed! on startup Quote Link to comment Share on other sites More sharing options...
chris morris Posted March 6, 2010 Report Share Posted March 6, 2010 agree with the above, probably the end of the cable not seated properly Quote Link to comment Share on other sites More sharing options...
anyoldiron Posted March 6, 2010 Report Share Posted March 6, 2010 Also...........there is a hassle free way of removing carb.It doesn't have to be a pig.It is well described in the Beta forum. Quote Link to comment Share on other sites More sharing options...
the addict Posted March 6, 2010 Report Share Posted March 6, 2010 Also...........there is a hassle free way of removing carb.It doesn't have to be a pig.It is well described in the Beta forum. Swap the air box/carb boot around so the larger end is to the carb, I also used to take the reed block spacer out, makes taking the carb off and sticking it back on a piece of p*** Quote Link to comment Share on other sites More sharing options...
