rezurect Posted September 16, 2010 Author Report Share Posted September 16, 2010 Well I started drilling it out but I couldn't get the swingarm to separate from the engine so it ended up as a combination of beating it out and wedging the frame a bit to hacksaw through it. The bolt came out easy enough after that. The new one will be getting drowned in copaslip when it goes in. Iain Quote Link to comment Share on other sites More sharing options...
rezurect Posted October 13, 2010 Author Report Share Posted October 13, 2010 Well I have recently had the frame welded on my bike and all parts are on order from splatshop. Once arrived I shall begin the task of rebuilding the beast. Fortunatley the bash plate has gone on without too much trouble and I have a rolling chassis for the engine to drop into once repaired. I see some discussion has taken place regarding engine oil. I take the concensus is to use 5w30 oil? Back to work tomorrow so once the spares arrive I will hopefully have some days off to get it rebuilt. Iain Quote Link to comment Share on other sites More sharing options...
copemech Posted October 14, 2010 Report Share Posted October 14, 2010 Well I have recently had the frame welded on my bike and all parts are on order from splatshop. Once arrived I shall begin the task of rebuilding the beast. Fortunatley the bash plate has gone on without too much trouble and I have a rolling chassis for the engine to drop into once repaired. I see some discussion has taken place regarding engine oil. I take the concensus is to use 5w30 oil? Back to work tomorrow so once the spares arrive I will hopefully have some days off to get it rebuilt. Iain The factory recommend on the gear oil was 10-40, though the other works fine with not much difference, possibly a bit quicker clutch, but they will likely both stick off cold and setting. No big deal. Quote Link to comment Share on other sites More sharing options...
rezurect Posted October 17, 2010 Author Report Share Posted October 17, 2010 Cheers cope.... Will go for that... Parts all here and rebuild imminent. Iain Quote Link to comment Share on other sites More sharing options...
