Oily Spits From Exhaust
skippy1234
Oil mix sounds more or less ok.Lampkins could give you a definite ratio.Try blasting up a long hill .Should smoke even more and clear.Or strip clean exhaust pipe and repack silencer.If it is otherwise running well then alls well.Probably just a build up of oily cak in the pipe.
ive just took rear box off and pulled the packing out it was tight and oiled up bad but when i squoze the packing there was a fair amount of water in with it is that normal i dont think the head gasket has gone as the oil is fine not milky any ideas cheers
mick
Guest DGShannon
mick
Wash it recently, without putting a plug in the exhaust outlet?
