4rt Clutch Cover, Aluminium?
stkman
Hi All,
Managed to put a hole in my 4RTs clutch cover today :crying: Will price up a new one but suspect they won't be in stock. Anyone know for certain if they are aluminium and therefore weldable?
Andrew
Definitely aluminium and weldable, I damaged mine at the cross drilling plug where the clutch fluid enters the casing and had no problem welding.
However distortion may be a problem if you have significant damage, over hear the cover was available ex stock and fairly cheap.
Good luck
Thanks OzThumper,
Cover is available here and not too bad pricewise. Should have the new one in a day or two but will have the hole welded up with a patch to use as a spare. Hopefully clamping it before welding will prevent the warpage ... will seek the welders opinion.
Andrew
