Tlr 200 Forks
martin 305
Hi there can anyone give me some advice on how to split my forks as i cant get the slider off :D Taken the bottom bolt out top nut off removed the damper rod and spring . taken out the circlip but cant get the slider off . Am i missing something ????? I need to change the seals and i thaught i would give em a good clean out but cant split em :wall: Cheers for any help :wall:
Bolt the fork back in the yokes tight and you need to pull the bottom down a few times like a slide hammer. You should be able to leave the springs and top nut all in situ and then lever the seal out carefully.
