Carb Gasket
squid
I think me gasket in between the float chamber and the main body has died. I dont know if its because I've opened up the carb about 4 times this week or its just old. Anyway after cleaning the insides to try and solve me latest problem fuels actually dripping out between the gap.
Is it best to buy the standard gasket or do many of you use a liquid sealer.
Cheers
Squid.
Squid,
UNDER NO CIRCUMSTANCES WHATSOVER ever use any silicone sealant anywhere near a carb!!!!!! Fit the correct gasket and do not over tighten! Undo it one more time, make sure it is seated correctly, refit the bowl, soft tap with ruber hammer and screw it up.
Tony
