Mont 242 Con Rod
bambam_n_chunx
Hi, You may find that a genuine 247 rod is little wider at the small end. This can be resolved by making modified small end endfloat control shims. Piston supply still seems to be a bit difficult, although we have found a couple of options. One involves moving piston ring pins, and another involves machining and replating the cylinder. If anyone has come up with a better option, please let me know! Regards Steve
Steve,I have fitted a steel liner,matched to a mahle 238 bultaco piston from dave renham,just had to drill two holes in the piston to match the transfer slots as per the origional piston.No problems with ring pins as they missed the ports.
Cheers,Paul.
