hoodie2 Posted March 20, 2010 Report Share Posted March 20, 2010 Hi all. Been collecting parts for my M92 project. I thought I had got a suitable rear wheel and brake plate, but now that I've checked I've got mismatched parts. The hub came from an m92, apparently, but it has bearing holders at 41.8mm ( must be for 42mm od bearing) and the bearing id seems to be 15mm. I have a brake plate that takes a 17mm spindle and I have a 17mm spindle that is about 260mm total length, with the 17mm section for 220mm of the length. The swinging arm is from an m92 frame and it has spindle slots with a height of about 17mm. If I measure it from the outside of one spidndle slot to the other it comes to about 195mm. So it looks like the frame needs a shorter 17mm spindle, the brake plate is okay, but the hub either needs replaced, or modified to take a different bearing, to allow for the 17mm id. I was thinking that someone must have worked through something like this before, so any advice would be much appreciated. Cheers. Quote Link to comment Share on other sites More sharing options...
myson Posted March 20, 2010 Report Share Posted March 20, 2010 (edited) I got a new spindle from Billetparts, (site sponsors) not expensive and good quality. may be a good place to start. They are very helpfull. Maybe a post from someone there may help. Good luck, Myson Edited March 20, 2010 by myson Quote Link to comment Share on other sites More sharing options...
