john b Posted March 21, 2010 Report Share Posted March 21, 2010 Sounds like how I planned to do it ian ! Quote Link to comment Share on other sites More sharing options...
ianwilson Posted March 21, 2010 Report Share Posted March 21, 2010 When you order the seal order the funny shaped o ring as well for water pump casing. Its a bit fidly to get back in but I stuck mine in with a bit grease to hold it in the slot. The whole lot delivered was less than a Quote Link to comment Share on other sites More sharing options...
john b Posted March 21, 2010 Report Share Posted March 21, 2010 Cheers ian, will do much appreciated john Quote Link to comment Share on other sites More sharing options...
sawtooth Posted March 22, 2010 Author Report Share Posted March 22, 2010 If you cant get the seal to stay put while putting the casing back on then lie the bike on its side. Quote Link to comment Share on other sites More sharing options...
kasob1964 Posted March 23, 2010 Report Share Posted March 23, 2010 Hi, If the seal replacement does not work it might be worth noting that the water pump case is made from Magnesium which is porous. If there is evidence of scuffing or corrosion in the Mg case the water can seep through into the gearbox. Replacement water pump case is about 60 squid. The newer cases are made with more Ally and are therefore less porous. Good luck! Quote Link to comment Share on other sites More sharing options...
sawtooth Posted March 24, 2010 Author Report Share Posted March 24, 2010 I have a new case so the seal is at fault. Quote Link to comment Share on other sites More sharing options...
john b Posted March 24, 2010 Report Share Posted March 24, 2010 Just went to change the seal - and there is a lot of evidence of corrosion, especially at the bottom of the impeller. Quite a few holes in there.... ! Is there a repair (metal-mend?) or am I looking at a new side casing.......... cheers John Quote Link to comment Share on other sites More sharing options...
sawtooth Posted March 24, 2010 Author Report Share Posted March 24, 2010 (edited) John B said: Just went to change the seal - and there is a lot of evidence of corrosion, especially at the bottom of the impeller. Quite a few holes in there.... ! Is there a repair (metal-mend?) or am I looking at a new side casing..........cheers John Hmm, unlucky, i think i read somwhere on here about using araldite to make a repair, try having a quick search on it. IIRC a new casing is Edited March 24, 2010 by SawTooth Quote Link to comment Share on other sites More sharing options...
ianwilson Posted March 24, 2010 Report Share Posted March 24, 2010 John, I thought the 08 had the alloy casing. Might be worth a call to Lampkins.I have heard of people using liquid metal ( think Isopon make it ). Worth a try. Quote Link to comment Share on other sites More sharing options...
sawtooth Posted March 24, 2010 Author Report Share Posted March 24, 2010 If it has the alloy casing its less likely to corrode but still possible. You may just have a load of old crusty coolant in there, have you scaped away the coolant to see if theres any actual corrosion? Quote Link to comment Share on other sites More sharing options...
