laser1 Posted March 24, 2010 Report Share Posted March 24, 2010 I encourage you to try different pilots and feel the difference for yoursel. Based on being at 3 and 1/2 turns out with the 33, I think your about as lean as I would make it now. But I like alot of power off the bottom and tune for aprox 3 turns out on the fuel screw - so I would try a 35 and also check it with a leaner needle setting. If you happen to end up liking the feel of the "smoother" 30, just check you dont get any pinging after you chop the throttle after a long climb and your not more than 4T out. Cheers. Quote Link to comment Share on other sites More sharing options...
jordi Posted April 7, 2010 Author Report Share Posted April 7, 2010 Quick update. Just done a 3 day in France with the 30 pilot fitted. No problems with it at all, bike felt good. Quote Link to comment Share on other sites More sharing options...
laser1 Posted April 8, 2010 Report Share Posted April 8, 2010 (edited) what are your observations regarding the change? what temp and altitude were you at? Edited April 8, 2010 by laser1 Quote Link to comment Share on other sites More sharing options...
jordi Posted April 9, 2010 Author Report Share Posted April 9, 2010 Bl--dy cold for 2 days then warm, altitude? centre of France is not much above sea level I think.. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted April 9, 2010 Report Share Posted April 9, 2010 Bl--dy cold for 2 days then warm, altitude? centre of France is not much above sea level I think.. probably max 1000ft. Quote Link to comment Share on other sites More sharing options...
