Brake Pedal
blocky
Work on my new toy (240pro) is going well but I need to make myself a new brake pedal. I have looked at a few and have come up with a design but I need to know how the standard pedal attaches to the frame as all I have is a hole in the frame where it should go.
Should there be some kind of bush pressed into this hole or what ?
Hoe does the pedal actually attach to the frame ? If bolted, what does it bolt to ?
Thanks in advance for your help
On the pedal there is a sleeve.The bolt is hexagonal at the top(ie it just looks like a normal 17mm bolt) then its just a short rod wide enough to fit the sleeve flush-no bush etc-the bolt here is smooth.The bolt then slims down with a thread on it and this is what bolts to the frame-thats it.Excuse the lack of technical language!
