blocky Posted March 23, 2010 Report Share Posted March 23, 2010 Work on my new toy (240pro) is going well but I need to make myself a new brake pedal. I have looked at a few and have come up with a design but I need to know how the standard pedal attaches to the frame as all I have is a hole in the frame where it should go. Should there be some kind of bush pressed into this hole or what ? Hoe does the pedal actually attach to the frame ? If bolted, what does it bolt to ? Thanks in advance for your help Quote Link to comment Share on other sites More sharing options...
anyoldiron Posted March 23, 2010 Report Share Posted March 23, 2010 On the pedal there is a sleeve.The bolt is hexagonal at the top(ie it just looks like a normal 17mm bolt) then its just a short rod wide enough to fit the sleeve flush-no bush etc-the bolt here is smooth.The bolt then slims down with a thread on it and this is what bolts to the frame-thats it.Excuse the lack of technical language! Quote Link to comment Share on other sites More sharing options...
