samo Posted March 24, 2010 Report Share Posted March 24, 2010 ELF HTX gearbox oil any good? A friend from me told me this is the best oil for engine..Is it true? I use ATF and I'm happy with it... Cheers Samo Quote Link to comment Share on other sites More sharing options...
lowbrow Posted March 24, 2010 Report Share Posted March 24, 2010 The biggest effect you'll notice using Elf is on your wallet Quote Link to comment Share on other sites More sharing options...
benz19 Posted March 24, 2010 Report Share Posted March 24, 2010 Elf is possibly the best gear box oil you can use,Honda recommend it,what more can be said!! YES it is more money,but then you will not need to change oil as often,so it balances out. I have used it in a 4rt,as recommended by Honda,and also in a 09 Gasgas 250 with no ill affects at all,lovely light smooth clutch,and the oil will stand a hell of a hammering!!! Benz. Quote Link to comment Share on other sites More sharing options...
