millerme Posted March 28, 2010 Report Share Posted March 28, 2010 want to change the oil on my mono would light gear oil be ok in the engine if so how much to put in or has any one used ATF as i use this in my gasgas pro Quote Link to comment Share on other sites More sharing options...
mikee Posted March 28, 2010 Report Share Posted March 28, 2010 I used ATF in my mono and i think i put 850ml in. It had no ill efect and made the clutch very light with know slipping... hope that helps a bit.... Quote Link to comment Share on other sites More sharing options...
fergie Posted March 30, 2010 Report Share Posted March 30, 2010 (edited) do not put gear oil in the tranny. +1 on ATF though Edited March 30, 2010 by fergie Quote Link to comment Share on other sites More sharing options...
pat Posted April 1, 2010 Report Share Posted April 1, 2010 From experince multi-/single grade for TYR (OT and KTM with Rekluse..) The only oil that works for my TYR gb/clutch is single grade 30w mineral (well, modern mineral contains "emu-cleaner" BUT.....) cheers, Quote Link to comment Share on other sites More sharing options...
millerme Posted April 3, 2010 Author Report Share Posted April 3, 2010 just spoke to a few trials shop they all say the same put light gear oil in 800cc the say that the engine will run on ATF but would not recommend it. But as MIKEE said his bike runs fine on it and his clutch works great so i think i will have a go with the ATF first see how it goes and it is thinner and should lube the small end bearing better Quote Link to comment Share on other sites More sharing options...
