pat Posted March 29, 2010 Report Share Posted March 29, 2010 Hi, Will kindly ask if any of you have found softer spring rates vs std for Amal MK1 throttle? BR, Pat Quote Link to comment Share on other sites More sharing options...
davetom Posted March 29, 2010 Report Share Posted March 29, 2010 Don`t know if this is relevant but I had an enduro bike with a Dellorto with a hefty spring, and the mod was to slowly run the spring along a bench grinder, so it ended up as a D shape in cross section. It worked on that anyway, as long as you dont go too mad! Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 29, 2010 Report Share Posted March 29, 2010 What twist grip are you using ? Quote Link to comment Share on other sites More sharing options...
pat Posted April 1, 2010 Author Report Share Posted April 1, 2010 Thanks DAVETOM, B40RT, Im using white tubed Domino, -ultra light with OKO set up. (same grip for my TYR/Keihin29S -ultra light, fathers Sprite with Villiers carb -light) ---------------------------------------------------------------------------------------------------- Yes, Im weak...but provided A_al spring rate is to hard for my trialing, no doubt about it. Will speak with some spring supplier. Cheers, Quote Link to comment Share on other sites More sharing options...
