triton Posted January 8, 2005 Report Share Posted January 8, 2005 Hi, thanks for help so far, more silly questions now!! Which tyre is ok for a wobbler on a cub? Is it worth the extra cash for an IRC or Michelin X11 or will a Pirrelli MT43 be ok, I need all the help I can get grip wise!! Is the width at the tread all the same as clearance is abit tight. Im on a very hard MT13 at the moment, terrain is usually woods mud etc. Rgds Quote Link to comment Share on other sites More sharing options...
superhondaman Posted January 8, 2005 Report Share Posted January 8, 2005 An IRC would be the first choice for grip then Michlen, the MT43 works well in mud ,soft ground & snow because of its fairly stiff oddly shaped blocks they clear well. If you are intending to ride rocks then give the MT43's a miss the side walls/blocks are too hard and the rear will bounce all over the place! P.S. www.rhencullen.co.uk have got some MT43's for about Quote Link to comment Share on other sites More sharing options...
dirtrider Posted January 9, 2005 Report Share Posted January 9, 2005 Up here in Yorkshire most people opt for the IRC. I use these on my B40 and they do perform well in both mud and on rocks. They provide a good deal of feel. Quote Link to comment Share on other sites More sharing options...
stickinthemud Posted January 17, 2005 Report Share Posted January 17, 2005 If you've ever been stuck in the bottom of a slimey bomb hole with the back wheel spinning you will soon realise why you need the best tyres you can afford. Some clubs don't allow tubeless either. MT43s are rock hard. Tyre pressures are also vital if you are going to get up those slippery slopes. 6lb in the front and 4 in the rear argueably seems the norm although a pound or so more on rocky going is also a good idea. Get a low pressure tyre gauge for consistency - don't guess! How often do you see a wobbler stationery with a rock hard back tyre! Quote Link to comment Share on other sites More sharing options...
triton Posted January 17, 2005 Author Report Share Posted January 17, 2005 Hi IRC tubed tyres are very difficult to find locally, can I fit a tube to an IRC tubeless tyre???? Quote Link to comment Share on other sites More sharing options...
g4321 Posted January 17, 2005 Report Share Posted January 17, 2005 Seeing the discussion is on tyres - has anyone tried the Mitas (barum) trials tyre ? Gordon Quote Link to comment Share on other sites More sharing options...
