mike64 Posted March 31, 2010 Report Share Posted March 31, 2010 After only my third trial I managed to snap the rear mudguard, so after taking advice, I got it repaired and then was stuck with a bit of a bodge and not sure what to do The repair was strong but the plastic was well past it's best So I invested Quote Link to comment Share on other sites More sharing options...
shercojay Posted March 31, 2010 Report Share Posted March 31, 2010 looks really good, i use that stuff to line my RC boats out with, only problem ive had is with the heat from the exhaust melting it a little Quote Link to comment Share on other sites More sharing options...
chris morris Posted April 1, 2010 Report Share Posted April 1, 2010 How Thick is the sheet? would it last a while if i put it on the sides of my frame? Quote Link to comment Share on other sites More sharing options...
scorpa Posted April 1, 2010 Report Share Posted April 1, 2010 This stuff is fairly thick, would think it would be fine on the frame. I work for a sign company and have got samples of this material, might have to order some in to have a play with. Quote Link to comment Share on other sites More sharing options...
shercojay Posted April 1, 2010 Report Share Posted April 1, 2010 the stuff i use is about 5mm thick Quote Link to comment Share on other sites More sharing options...
mike64 Posted April 1, 2010 Author Report Share Posted April 1, 2010 The vinyl I've used is quite thin - approx 0.25mm here's a link to the 3M website http://solutions.3m.co.uk/wps/portal/3M/en...c_id=PPC_Cfibre I'm going to put it on the scorpa frame where my boots rub - not sure if it will last though cheers pm me for any info or if you want your's repaired for a nominal fee Quote Link to comment Share on other sites More sharing options...
