matt_urban Posted April 1, 2010 Report Share Posted April 1, 2010 hello all my rev 3 cuts out when going downhill slow is this normal if i give it revs its fine and it ticks over on the flat fine ? Quote Link to comment Share on other sites More sharing options...
the addict Posted April 1, 2010 Report Share Posted April 1, 2010 Float height wrong I expect Quote Link to comment Share on other sites More sharing options...
westygas270 Posted April 1, 2010 Report Share Posted April 1, 2010 go on beta uk m8 website, tells you how to set carb up, float height wants adjusting, m9 did exactly the same need to be spot on to run perfect, if you get stook give lampkins aring there allways help. Quote Link to comment Share on other sites More sharing options...
betarick Posted April 1, 2010 Report Share Posted April 1, 2010 float height float bowl cap and sort jets out and its a decent carb! sorted mine out when it was new 06 250cc rev3 and i have had no bother since once carb is sorted no need to touch it again! Quote Link to comment Share on other sites More sharing options...
darrensn Posted April 2, 2010 Report Share Posted April 2, 2010 had the same problem, sent my carb off to BVM moto, they set it up for me and return posted it ..... bike ran better than ever cost Quote Link to comment Share on other sites More sharing options...
matt_urban Posted April 4, 2010 Author Report Share Posted April 4, 2010 Might send it away then does anyone have a simple way of setting a carb up ? and is it easyer to get the carb off whith the intake pipe on backwards ? what way is backwards my pipe could be on backwards so if someone has a pic that would help me cheers Quote Link to comment Share on other sites More sharing options...
grahamcota Posted April 21, 2010 Report Share Posted April 21, 2010 Westy Wherabouts on the Beta site is that carb set up thingy you talk about. Regards Graham Quote Link to comment Share on other sites More sharing options...
betarev3 Posted April 26, 2010 Report Share Posted April 26, 2010 Hi - carb setup here Quote Link to comment Share on other sites More sharing options...
