rustybay Posted April 2, 2010 Report Share Posted April 2, 2010 Hi there My jt35 stops running after 2-3 mins , if not reved up? only will then start if i have the choke on, then turn it off even if hot bike has been laied up for sum time,put in new fuel there are two screws on the carb one small , one that is spring loaded what do they do? kind regards wayne Quote Link to comment Share on other sites More sharing options...
tt5th Posted April 2, 2010 Report Share Posted April 2, 2010 You'll need to clean your carb out I reckon. The two screws, one with the spring sets the idle speed - you could try turning that up - and the other one sets the idle mixture. Quote Link to comment Share on other sites More sharing options...
kkim Posted April 4, 2010 Report Share Posted April 4, 2010 http://www.thisoldtractor.com/gtbender/mg_...a_guide_1.1.pdf http://www.thisoldtractor.com/gtbender/mg_...orto_manual.pdf Quote Link to comment Share on other sites More sharing options...
rustybay Posted April 5, 2010 Author Report Share Posted April 5, 2010 Hi kkim Thanks for the info . Will try to set up Quote Link to comment Share on other sites More sharing options...
