bogwheel Posted April 6, 2010 Report Share Posted April 6, 2010 Need new fork springs - current springs are do not know type (one is slightly longer, and have a valve spring squished in as well) They also top out at full extension. Being only 63kg (about 8 and a bit stone) should i go with the sherpa or the pursang springs. And also can anyone comment on non-leading axle pursang fork bottoms or fitting Alpina triple clamps please? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted April 6, 2010 Report Share Posted April 6, 2010 Either mod will make the steering noticably heavier when riding slowly or stopped. If you want to try it you are welcome to ride my M138 Alpina, or I can lend you a set of Alpina/Pursang/Frontera triple clamps to try on your Sherpa T. Regards David Quote Link to comment Share on other sites More sharing options...
