2004 Txt Pro 280
krisbgasgas
I'm just tackling a little niggle i have with the bike.
When i rev the bike the revs slowly die down. I'm thinking in the back of my mind that the bike is running too lean. I'm going to try dropping the needle clip down 1 to see if this makes a difference.
BTW the bike has a Keihin carb fitted.
i've had the casing off and i dont think there is a flywheel weight on there.
i've changed the e clip on the throttle needle to 2nd from the bottom nad its made it a little better. if i do the bottom or middle clip it is quite rough when applying the throttle it bogs down likes its trying to die.
The air screww is 2 1/2 turns out aswell.
