benbeta23 Posted April 12, 2010 Report Share Posted April 12, 2010 Hi, About a month ago this strange Tizz/High pitch Buzzing sound started on My 2010 Evo 290, Then the week after it dissapeared and didn't come back, Strangly Yesterday it came back & it sounds as though to me it is coming somewhere from near the flywheel, had the ignition cover off and everything seems to be running ok inside, the noise has no effect on the engine, still runs perfect. At first i suspected it was the Fan rubbing against the radiator, but it wasn't that. The bike isn't overheating, the noise doesn't go away when you pull the clutch in, also noticed it only does it when the engine is warm, not when cold. gearbox oil is ok and the bike is running perfectly fine, just a strange high pitch noise coming from near the flywheel area, Just wondering if anyone has had this problem on your Evo's Thanks for your help, Ben. Quote Link to comment Share on other sites More sharing options...
tonybroad Posted April 12, 2010 Report Share Posted April 12, 2010 is the flywheel simply scraping the inside of the cover ? tony Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted April 12, 2010 Author Report Share Posted April 12, 2010 (edited) Nope, We have run the bike without the cover on, & still the same. Edited April 12, 2010 by GasGasben Quote Link to comment Share on other sites More sharing options...
eddie_lejeune Posted April 12, 2010 Report Share Posted April 12, 2010 flywheel weight is tight? Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted April 12, 2010 Author Report Share Posted April 12, 2010 Yep it's tight. Quote Link to comment Share on other sites More sharing options...
ianwilson Posted April 12, 2010 Report Share Posted April 12, 2010 Try moving the cable that comes out of the casing with the engine running. My mates Rev 3 did it after fitting new electrics. The flywheel was slightly catching the cable. There are posts on here relating to the Evo flywheel wearing through the electrics. If you have a puller I would remove the flywheel anyway and have a look. Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted April 12, 2010 Author Report Share Posted April 12, 2010 (edited) Try moving the cable that comes out of the casing with the engine running. My mates Rev 3 did it after fitting new electrics. The flywheel was slightly catching the cable. There are posts on here relating to the Evo flywheel wearing through the electrics. If you have a puller I would remove the flywheel anyway and have a look. Brill mate, thanks for the advice, will give it a go! Also forgot to mention the more you rev the bike, the louder it is. Edited April 12, 2010 by GasGasben Quote Link to comment Share on other sites More sharing options...
liviob Posted April 25, 2010 Report Share Posted April 25, 2010 Well, the suspense is killing me. What was causing the sound? Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted April 26, 2010 Author Report Share Posted April 26, 2010 (edited) No Idea as yet, the sound has now dissapeared again, hopefully going to take the flywheel off this week and take a look, still not had chance yet. Will keep you posted though when i know what was causing it. Edited April 26, 2010 by GasGasben Quote Link to comment Share on other sites More sharing options...
