twinkletoes Posted April 16, 2010 Report Share Posted April 16, 2010 what does this mod consist of? new frame and arm? strengthening of original frame? presuming lampkins did them under warranty? what was the actual fault originally? how can i tell if a used evo has had it done? did all 09's need it done or did they sort it during 09 production. answers appreciated, thanks Quote Link to comment Share on other sites More sharing options...
thedee Posted April 16, 2010 Report Share Posted April 16, 2010 Hi i had a 09 evo with the frame mod done and i had to have a new swing arm under warrenty as the original one cracked!! You can tell the frame mod as there are gussets round the fuel cap and on the under side behind the head set. As for the swing are the only thing that was different is the stand mounting, its right underneath by the dog arm mounts where as the old one was just mounted on the bottom of the swing arm. My original swing arm cracked in two places where the dog arm mounts are so keep a eye out!! Hope this helps. Quote Link to comment Share on other sites More sharing options...
