Beta 80 08 White In The Oil?
mickmc
Hi i have a problem with my sons beta it keeps getting white in the oil, which i think is most likely water, i was told it was the window seal, (indicator to show how much oil is in it)
i've replaced the seal (rubber ring thingy) where you put the oil in,
was told that the seals were checked and ok for the water pump, but haven't checked myself
is there anywhere else it could be coming from
any advice on how to fit the water pump seals if you think it is that
any advice appreciated
thanks in advance
thanks in advance
Water pump seals are the least expensive, and easiest to remedy. Good place to start !
thanks for your replies, i will try the water pump seals, i haven't noticed water disappearing, it's just when i empty the oil it looks slightly milky in colour, through parts of it, and when you look at the window level, with new oil in, rode it once and the window looks white again
