damorev3 Posted April 21, 2010 Report Share Posted April 21, 2010 I want to mod my tlr footrest position but dont know how far down or back to go .Any help thanks Quote Link to comment Share on other sites More sharing options...
jimmyl Posted April 22, 2010 Report Share Posted April 22, 2010 I cut the original brackets off mine which revealed a hole through the frame. I used this as the centre point for the mounting bracket of the new foot rest - I bolted and weleded new brackets on using this hole for the bolt to go through. (if you look behind existing hangers you can see this hole) Then fitted Mont 315 footrests as I had spares. I think aprox 1 " down and 1" back. Not sure if this is optimum but felt lots better and was easist option You can buy footrests that give same effect that use existing factory mounts Quote Link to comment Share on other sites More sharing options...
andy m Posted April 22, 2010 Report Share Posted April 22, 2010 You can buy footrests that give same effect that use existing factory mounts http://tyoffroad.webeden.co.uk/#/footrests/4532189376 Quote Link to comment Share on other sites More sharing options...
damorev3 Posted April 22, 2010 Author Report Share Posted April 22, 2010 thanks for advice guys Quote Link to comment Share on other sites More sharing options...
