viciousvinny Posted April 23, 2010 Report Share Posted April 23, 2010 hello again all, is this what i need for my 2005 320, will this fit straight on to all existing inlet etc/throttle cable/hot start? and if it will, what jets would i need, its on that well known auction site item number 250597116566 ? thanks Dave Quote Link to comment Share on other sites More sharing options...
copemech Posted April 24, 2010 Report Share Posted April 24, 2010 hello again all, is this what i need for my 2005 320, will this fit straight on to all existing inlet etc/throttle cable/hot start?and if it will, what jets would i need, its on that well known auction site item number 250597116566 ? thanks Dave Takes a bit of piddling for sure. Bobtlr would be the one to PM, but I think the inlet rubber would need changing(Sherco part from '08). Because of the fixed top cable mount on the 24 that I have on the 2.9, I had to use the top lid off my 28(threaded) and then the modded tube thing and adjuster off the original dellorto. If you have these things it is no big deal, otherwise you may need to get a lot of little stuff to put it together. Yet all can be had. Quote Link to comment Share on other sites More sharing options...
