scotty97 Posted April 24, 2010 Report Share Posted April 24, 2010 How much gearbox oil goes in a 2007 sherco 290, i've downloaded a manual from the shercoUSA website but it only shows a 2003 model. It states in there that 450ml of oil is to be used, and is the drainage bolt in the same place as on the 2003 model. On the side of the engine, opposite side of the the engine from the filler plug?????????? Quote Link to comment Share on other sites More sharing options...
johnnydudeuk Posted April 24, 2010 Report Share Posted April 24, 2010 Hi It's the same at 450cc's. From what I can see they have evolved rather than big changes each year. Well,upto 2010 anyway. Quote Link to comment Share on other sites More sharing options...
neo Posted April 27, 2010 Report Share Posted April 27, 2010 How much gearbox oil goes in a 2007 sherco 290, i've downloaded a manual from the shercoUSA website but it only shows a 2003 model. It states in there that 450ml of oil is to be used, and is the drainage bolt in the same place as on the 2003 model. On the side of the engine, opposite side of the the engine from the filler plug?????????? Yes it's still the same after all these years. Not sure why having them on "opposite sides" is an issue to you? Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
scotty97 Posted April 27, 2010 Author Report Share Posted April 27, 2010 Its not an issue, i was just tring to find out if i was on about the right bolt. Quote Link to comment Share on other sites More sharing options...
