farino Posted April 26, 2010 Report Share Posted April 26, 2010 Hi, can anyone help with my friends rear brake prob on a 97/98 250 beta. System is full of fluid, press down the rear brake pedal and nothing happens. Thought there maybe a blockage somewhere so disconnected and cleaned the system. Found that no fluid was pumping through. Got another brake cylinder pump, fitted it but when we come to bleed it hardly anything is coming out of the nipple. Is there something we are doing wrong as it seems straight forward? I know the pump works because when you manually push the rod in the piston fluid comes out. Any help would be very much appreciated. cheers Quote Link to comment Share on other sites More sharing options...
betarev3 Posted April 26, 2010 Report Share Posted April 26, 2010 Try a search - this has been covered extensively in the past Quote Link to comment Share on other sites More sharing options...
skippy1234 Posted April 26, 2010 Report Share Posted April 26, 2010 im having the same prob with my clutch getting close to getting the hammer out Quote Link to comment Share on other sites More sharing options...
