Rear Brake
farino
Hi, can anyone help with my friends rear brake prob on a 97/98 250 beta.
System is full of fluid, press down the rear brake pedal and nothing happens. Thought there maybe a blockage somewhere so disconnected and cleaned the system.
Found that no fluid was pumping through. Got another brake cylinder pump, fitted it but when we come to bleed it hardly anything is coming out of the nipple.
Is there something we are doing wrong as it seems straight forward? I know the pump works because when you manually push the rod in the piston fluid comes out.
Any help would be very much appreciated. cheers
