1999 315 - Sounding A Bit Like A Tractor!
lingo75
Hello chaps,
my 99 mont has developed a worrying noise from the engine, only way i can describe it is 'a bit rattly' or 'a bit like an old tractor!' no difference in performance just a lack of the nice purring i used to have. Should i take the crank case covers off and see if the flywheel is loose - any other ideas? is it all gonna go pear shaped if i leave it?? (i dont want to do that i want it sounding nice again!)
many thanks
Dan
Edited by Lingo75
Did it start suddenly or has it just got gradually worse?
Does it happen in a particular part of the rev range?
Leaving it will be a bad thing in the long run.
Checking the flywheel is easy enough, it could be the top end which is easy enough to take off and have a look.
Worst case it could be the bottom end, best case it could be a leak in your exhaust somewhere or something else equally simple.
Sometimes you can find the spot where its knocking by putting the metal end of a screwdriver against various parts of the engine and putting the rubber end on your ear. Works like a cowboy stethoscope!
Thanks for the reply!
Well it started this weekend, never noticed it before.
Funny you should say about the exhaust as i had had the front pipe off to spray it this weekend and i think it was after i replaced it that i noticed the noise, could that be it??
Always start with the last thing you did to the bike, when trying to isolate a problem !
ha.
Yeah i get that, but i due to my lack of the knowse i don't know why refitting the exhaust could cause a knocking/rattle.
Is it because it is not sealed/air tight?? and what does that do to make the noise??
sorry for all the questions. But i guess that's one of the reasons for a forum??!!
Aha, gotcha muchos gracias!
I dont think it is though (will check) the noise deffo sounds like it is coming 'from within' which is a worry!!!
in answer to initial questions
Well i noticed it on Saturday and have never heard it before so i'd say gradually. It hasn't got worse (rode a trial with it like it on Sunday)
Nope just always there in the background, no change in performance
Thanks in advance to anyone who replies. I really really appreciate it.
Ta
Dan
Definately double check the exhaust if that's something you've had off. Make sure it's all sealed nicely and the gasket didn't fall out/off when you removed it. I only mentioned it as on one of my other bikes I could have sworn it was tapping and it just turned out to be a loose exhaust manifold bolt so it wasn't sealing properly.
Rattling in the top end usually changes with revs. Normally worse when the engine is settling back down after a high rev.
Check all the simple things first though, 315's are usually bombproof.
Thanks all.
Should there be a 'proper' gasket where the front pipe goes in the engine. As i seem to remember it just looked a bit liek clear silicone or sort of off colour rubber. I reckon i need to put a new kind of seal on there - what should i use??
