Clutch Clutch Clutch ...hammer
skippy1234
cant bleed me @@@@@@ clutch tried the normal way tried back bleeding cant seem to push the fluid backwards am i doing it right 99 techno if you read my posts ive renewed mains crank seals all as a novice put it back together sweet as anything even invented my own fly wheel holding tool but i cant bleed this bleeding clutch please help
Gday, does the clutch master cylinder piston return fully to the circlip? If not this will block the port and make back bleeding impossible. It also may be blocked with rubbish inside. Have a good look in this area first.
Cheers,
Stork
