rij Posted April 27, 2010 Report Share Posted April 27, 2010 hi, Driving me mad is a dellorto phbh26 it s over flowing. adjusted float height. its had a new float valve. turn it upside down blow down the fuel intake and its sealed, put the bowl back on and it leaks fuel again. scorpa easy 1996 250 rotax any ideas?? rij Quote Link to comment Share on other sites More sharing options...
wherry Posted April 27, 2010 Report Share Posted April 27, 2010 Have you seen this? ApexMotorsports It's a Montesa parts list but the page linked to is for the PHBH carb. May enable you make sure that everything is as it should be. Float height on these is usually 18.5mm. Have you got the overflow pipe on the right outlet? Are the floats free to move when you put the bowl back on? Impossible to see I guess but is there anything that could be stopping them moving? Quote Link to comment Share on other sites More sharing options...
geebee Posted April 27, 2010 Report Share Posted April 27, 2010 Hi Have you checked the floats are not punctured. I had a float fill with fuel which caused a similar problem. Quote Link to comment Share on other sites More sharing options...
geebee Posted April 27, 2010 Report Share Posted April 27, 2010 Hi Again Also check that the floats are correctly orientated. Flat to bottom of float bowl. A good check is to give the carb a gentle shake after reassemby and hear the floats move. Quote Link to comment Share on other sites More sharing options...
rij Posted April 27, 2010 Author Report Share Posted April 27, 2010 Hi, floats are ok not punctured, can't really tell if there moving when its all together but all seams free when the float bowl is off. the diagram look the same all present and correct! rij Quote Link to comment Share on other sites More sharing options...
tt5th Posted April 27, 2010 Report Share Posted April 27, 2010 Also check your needle valve is seating properly. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted April 27, 2010 Report Share Posted April 27, 2010 Try with the float bowl off fuel is stopped by slight pressure up wards ie needle is doing its job. Float height measurement upside down of course. Quote Link to comment Share on other sites More sharing options...
rij Posted April 27, 2010 Author Report Share Posted April 27, 2010 Ok can hear floats moving. Carb assembled turned upside down blow down the fuel intake and it shuts off still. floats are floating. turn correct way up and it leaks!! just taken apart completely no dirt everything blows through clean?? Quote Link to comment Share on other sites More sharing options...
woodbutcher Posted April 27, 2010 Report Share Posted April 27, 2010 SOUNDS LIKE THE TWO FLOATS ARE INSTALLED UPSIDE DOWN AND SMALL TANGS ARE NOT PUSHING UP AGAINST FUEL VALVE ARM WHEN FILLING WITH FUEL AND OVERFLOWS BECAUSE IT WONT SHUT FUEL OFF AT WHAT SHOULD BE CORRECT LEVEL Quote Link to comment Share on other sites More sharing options...
rij Posted April 28, 2010 Author Report Share Posted April 28, 2010 Hi the floats cant be upside down, it does not fit and would have to be forced to close it. anybody got a cheap mikuni of a beta or tk off a tyz yamaha??? rij Quote Link to comment Share on other sites More sharing options...
bowershall Posted April 28, 2010 Report Share Posted April 28, 2010 I can confirm that the floats can be fitted the wrong way! 1 Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted April 28, 2010 Report Share Posted April 28, 2010 Ok can hear floats moving. Carb assembled turned upside down blow down the fuel intake and it shuts off still. floats are floating. turn correct way up and it leaks!! just taken apart completely no dirt everything blows through clean?? So you have tried it on the bike with the float bowl off? Quote Link to comment Share on other sites More sharing options...
rij Posted April 28, 2010 Author Report Share Posted April 28, 2010 yeah, float bowl off gently push float tabs up and it tuns off. I've tried floats the other way but it would have to be forced on and that would keep the float valve shut tight. i have got the floats i with the pin at the bottom. rij Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted April 29, 2010 Report Share Posted April 29, 2010 yeah, float bowl off gently push float tabs up and it tuns off. I've tried floats the other way but it would have to be forced on and that would keep the float valve shut tight. i have got the floats i with the pin at the bottom. rij Right so it is established to be working fine.turn upside down and check 18.5 and its done if it floods then something is happening when the bowl is on. brass thingy ok >? Quote Link to comment Share on other sites More sharing options...
rij Posted April 29, 2010 Author Report Share Posted April 29, 2010 yeah all look straight and original, ive showed this to a couple of guys i work with, who are motorcycle mechanics and its got them baffled as well!! i feel like grinding into a thousand pieces!!! rij 1 Quote Link to comment Share on other sites More sharing options...
