gordo Posted May 2, 2010 Report Share Posted May 2, 2010 Hello, Looking to make my Ossa clutch a little easier to pull. I have a Teflon cable. Just wondering if anyone has done anything with springs. Taking all suggestions. Thanks. Quote Link to comment Share on other sites More sharing options...
woody Posted May 2, 2010 Report Share Posted May 2, 2010 Extend the arm as far as it will go (1.5 inches maybe, can't remember) but you'll also need to relocate the lug where the outer cable locates to keep the cable straight. This is easy enough by using the existing locater lug to bolt a bracket to with a new locater to line up with the end of the arm. Lighter springs are available her in the UK but I found that under a severe caning in 2nd or 3rd gear on steep muddy climbs they could slip, even with the adjusting screws bottomed out, so I reverted to the original springs. Depends how hard you ride your bike. With less 'severe' usage they would be ok. My '75 350 MAR has the arm lengthened, Barnett plates, standard springs, adjusting screws are set so there are a few threads showing, they aren't bottomed out. I use a Venhill superlight cable. With this set up I get one finger clutch pull and the Barnett plates ensure it disengages every time. Engagement with the extended arm is fine, no problems. Basket is in good order, no rough edges etc. which helps smooth operation as well. Quote Link to comment Share on other sites More sharing options...
