bogwheel Posted May 3, 2010 Report Share Posted May 3, 2010 hi My Sherpa is fitted with an RL stator plate and flywheel (not sure what coil / ignition is though) I find that the bike is playing up when hot (similar to when timing is out or when starving for fuel) the bike runs fine for about 15 - 20 minutes. Bike starts first kick always, hot or cold. Could this be a fault in the cdi system? thanks Quote Link to comment Share on other sites More sharing options...
tony27 Posted May 3, 2010 Report Share Posted May 3, 2010 Generally ignition problems when hot are caused by the insulation in the primary/stator coils breaking down although the problem is normally the spark disappears when hot then reappears when things have cooled back down Not sure if thats any help to you Quote Link to comment Share on other sites More sharing options...
