dalmahoy Posted May 3, 2010 Report Share Posted May 3, 2010 Out yesterday - before heading off I was heard to comment how cheap trails bikes are to run compared the the KTM 200EXC. 20 minutes later I'm pushing the thing back to the van as a result of no spark. No warning or anything - the thing just cut out and that was it. Reckon the stator problem has raised its head. I had already unplugged the kill switch. Bike in question is a 2007 Beta Rev 3 250. Any ideas on what to check before the cheque book comes out? Cheers Rob Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted May 3, 2010 Report Share Posted May 3, 2010 Out yesterday - before heading off I was heard to comment how cheap trails bikes are to run compared the the KTM 200EXC.20 minutes later I'm pushing the thing back to the van as a result of no spark. No warning or anything - the thing just cut out and that was it. Reckon the stator problem has raised its head. I had already unplugged the kill switch. Bike in question is a 2007 Beta Rev 3 250. Any ideas on what to check before the cheque book comes out? Cheers Rob woodruffe key? Quote Link to comment Share on other sites More sharing options...
dalmahoy Posted May 3, 2010 Author Report Share Posted May 3, 2010 Was thinking if its the woodruff key - the thing would still spark though - just not at the right time. The plugs not kicking out anything. Quote Link to comment Share on other sites More sharing options...
bricklane Posted May 3, 2010 Report Share Posted May 3, 2010 CDI unit i reckon would be worth checking.. Quote Link to comment Share on other sites More sharing options...
stork955 Posted May 3, 2010 Report Share Posted May 3, 2010 Gday, its probably the stator. Check wiring loom for any damage (outside chance) but most likely that is the issue. There is heaps of info -search the Beta forum. You are right - a sheared key will still give a spark, just at the wrong time. Cheers, Stork Quote Link to comment Share on other sites More sharing options...
dalmahoy Posted May 4, 2010 Author Report Share Posted May 4, 2010 Had a first look last night - on removing the flywheel cover - there's a fair bit of condensation and corrosion on the flywheel. The flywheel nut is a tight one though. An air rachet will be required to get this thing off. Small air compressor I have is just not up to it. Quote Link to comment Share on other sites More sharing options...
dalmahoy Posted May 12, 2010 Author Report Share Posted May 12, 2010 New stator arrived yesterday - once flywheel was off - I was surprised the amount of cack sitting behind it. Existing stator was very gummed up. Gave it a good clean and blow out with an air line. Fitted the new stator but wasn't able to start the bike - not sure the torque setting for the flywheel. Turning it over on the kick start - a nice fat spark has re-appeared. Quote Link to comment Share on other sites More sharing options...
mcharchuk Posted May 12, 2010 Report Share Posted May 12, 2010 New stator arrived yesterday - once flywheel was off - I was surprised the amountof cack sitting behind it. Existing stator was very gummed up. Gave it a good clean and blow out with an air line. Fitted the new stator but wasn't able to start the bike - not sure the torque setting for the flywheel. Turning it over on the kick start - a nice fat spark has re-appeared. The torque settings are in this thread http://www.trialscentral.com/forums/index....showtopic=28936 Quote Link to comment Share on other sites More sharing options...
dalmahoy Posted May 13, 2010 Author Report Share Posted May 13, 2010 Using a strap wrench last night to lock the flywheel - managed to get the flywheel nut very close to the required torque before the thing started slipping - annoying because because its so close. Planning to look for a better wrench tonight. Bike started first kick though. Once the flywheel is torqued - I'm happy again. Looked at using the flywheel weight screws to hold the thing but they're in tight. Tried the impact driver on them but there's no sign of movement. Bikes not far away now though. Quote Link to comment Share on other sites More sharing options...
monkeyboy Posted May 13, 2010 Report Share Posted May 13, 2010 Told you to buy a Scorpa Rob ............. Roll on Saturday http://www.redtread.com/ here we come !! Quote Link to comment Share on other sites More sharing options...
