Cdi Unit Problems
mooregas
Ive got an ignition problem with a 280 06 pro, theres no spark, theres a live from the stator to the voltage reg(yellow wire) and from the voltage reg(yelow wire) to the cdi, and all the earths are good, but i carnt get a live at the lead! a new cdi is
It may be worth changing out the regulator first. I've had two of these fail in the past on a 2004 and 2006 pro. Both times I appeared to be getting an output but obvioulsy not enough under load.
