geebee Posted May 10, 2010 Report Share Posted May 10, 2010 Hi Has anyone designed a strengthener plate for the down tube? Our 2010 has a dent where the bottom yoke has hit the down tube. Seems like a common problem with the 2010 Sherco. I have thought about epoxying a half pipe 1/2"nb sch 10s SS over the dent. Quote Link to comment Share on other sites More sharing options...
neo Posted May 10, 2010 Report Share Posted May 10, 2010 (edited) Can you post up a photo of this? Best of balance. Neo Edited May 10, 2010 by Neo Quote Link to comment Share on other sites More sharing options...
jonnybmac Posted May 10, 2010 Report Share Posted May 10, 2010 A lad who I've spoke to at charltons has put a dent in his exhaust downpipe Quote Link to comment Share on other sites More sharing options...
copemech Posted May 11, 2010 Report Share Posted May 11, 2010 I have not seen one hit hard enough to damage a tube, but I think you may have the right idea. If you are referring to using stainless steel tube, it can be a bit soft, but better than nothing. Quote Link to comment Share on other sites More sharing options...
geebee Posted May 11, 2010 Author Report Share Posted May 11, 2010 Sherco 2010 sustained damage to down tube Please find attachment showing sustained damage to down tube Quote Link to comment Share on other sites More sharing options...
tony27 Posted May 11, 2010 Report Share Posted May 11, 2010 (edited) I'll be nice I've seen worse but generally large rocks have been involved Edited May 11, 2010 by tony27 Quote Link to comment Share on other sites More sharing options...
neo Posted May 11, 2010 Report Share Posted May 11, 2010 Gosh!!....Now I get it. This is a very sad photo ....How the hell can this be fixed and restored to it's original strength? I guess it's one of the negative effects of having such a good steering lock.... it leaves those down tubes more exposed.....And another concern is the way the rad has taken a wack too I wish you the best of luck finding some way of fixing this properly. Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
houseape1000 Posted May 11, 2010 Report Share Posted May 11, 2010 (edited) What is the frame made out of ? I would suggest cutting the dented area out, and welding in a new piece. Tig and purge.....then clean off and grind smooth again. The beauty of tig is the heat is kept local, so not much of a touch up job afterwards ! Or, you could just build the affected area up with a few runs of weld, then grind smooth again. Is there any way of glueing a bit of rubber to the yokes or to the frame to soften the impact.......should there be one. Edited May 11, 2010 by houseape1000 Quote Link to comment Share on other sites More sharing options...
shercofray Posted May 11, 2010 Report Share Posted May 11, 2010 What is the frame made out of ?I would suggest cutting the dented area out, and welding in a new piece. Tig and purge.....then clean off and grind smooth again. The beauty of tig is the heat is kept local, so not much of a touch up job afterwards ! that will take the strength out of the frame obviously! Quote Link to comment Share on other sites More sharing options...
houseape1000 Posted May 11, 2010 Report Share Posted May 11, 2010 that will take the strength out of the frame obviously! Not really, depends on who does it though I suppose ! Quote Link to comment Share on other sites More sharing options...
ishy Posted May 11, 2010 Report Share Posted May 11, 2010 Simple cheap fix, the damage is caused by the lower tripple clamp hitting the frame, the mod stops this. All that is needed is a bit of plastic pipe, I used half inch water pipe, about 1.1/2 " long then cut down the length to snap on the frame tube. This mod was posted on the RYP site a few weeks ago, I think the factory will probably beef it up for the 2011 model. Quote Link to comment Share on other sites More sharing options...
wayne thais Posted May 11, 2010 Report Share Posted May 11, 2010 (edited) I would not cut the frame. The solution that Ishy shows should work. Gas Gas pro bikes have a piece of rubber that is used to prevent denting the frame. Edited May 11, 2010 by Wayne Thais Quote Link to comment Share on other sites More sharing options...
for artie Posted May 12, 2010 Report Share Posted May 12, 2010 What happen to putting fork stops on the frame? Poor design Sherco. Quote Link to comment Share on other sites More sharing options...
copemech Posted May 12, 2010 Report Share Posted May 12, 2010 What happen to putting fork stops on the frame?Poor design Sherco. This does not really happen nowadaws, reguardless of brand. If you bash any of the steel framed bikes hard, they will bend. The normal material is 4130 tubing, or a slight derivitive, which can easily be welded without problem, yet is only a mild steel in itself, and works well as it has desireable attributes in other aspects of stress and such. I can tell the bike in the pic came down hard on the bars. Full inpact probably, from just how high? Do not know. Was it enough to take out the fatbars as well? Possibly so. Quote Link to comment Share on other sites More sharing options...
geebee Posted May 12, 2010 Author Report Share Posted May 12, 2010 Hi It was a big off in Scotland. It happened on the track on Wednesday up to Mamore Road but the bike finished the week. A visual inspection shows no damage to the bars but the rider was somewhat detuned. Other damage includes a dented fuel tank and scars on the exhaust. Work now begins to put things right Quote Link to comment Share on other sites More sharing options...
