slowdirt Posted May 11, 2010 Report Share Posted May 11, 2010 I have a 2000 290 with the forks set on the second mark down. Is that correct? What changes if I raise or lower the forks to the other marks? Thanks Quote Link to comment Share on other sites More sharing options...
tony27 Posted May 11, 2010 Report Share Posted May 11, 2010 Dropping the forks down-all marks above the top yoke will speed up the steering slightly & load up the front tyre more, going the other way-top of fork flush lifts the front end & makes lofting it easier at the expense of slightly less precise steering. Honestly the differences are quite small & not that noticeable. I run mine in the mid point as a good compromise Quote Link to comment Share on other sites More sharing options...
