colin1212 Posted May 16, 2010 Report Share Posted May 16, 2010 Silly question but may aswell ask because I haven't got a clue about it. When im going along in my bike at high revs or off a jump the kickstart just sticks out. I have tightened it but just keeps on sticking out. Quote Link to comment Share on other sites More sharing options...
johnkennedy Posted May 16, 2010 Report Share Posted May 16, 2010 i had this problem with mine aswell (ages ago), if you take the lever off there should be a ball bearing and a spring that presses against the "Kickstart Pedal Base"(the little part thats on the shaft). The spring may have lost tension or broken, just use a larger ball bearing or a new/bigger spring. check out the manual http://www.gasgasmotos.es/es/trial/2-txt-pro-250-cc.html Under Despiece, page 37 Quote Link to comment Share on other sites More sharing options...
