zarkoff Posted May 20, 2010 Report Share Posted May 20, 2010 hi there can any body point me in the right direction , my honda back fires mostly at high revs it seems to stop if i rev it out. it is points ignition. i dont know were to start as it used to run perfectly . i think i have every thing set correctly could it be the advance retard mec perhaps? where should i start fuel or ignition? Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 20, 2010 Report Share Posted May 20, 2010 I would drain carb, and change the plug. After that try another coil if you can borrow one. Quote Link to comment Share on other sites More sharing options...
zarkoff Posted May 20, 2010 Author Report Share Posted May 20, 2010 I would drain carb, and change the plug.After that try another coil if you can borrow one. hello . the carb is clean i have a coil of another bike of roughly the same era i could try maybe . i did replace the condensor about a year and a half ago but ive only done about 4 trials on it i think i will try a new set of points as well and then see ,the plug by the way was a perfect color when i took it out so i am still wondering . Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 20, 2010 Report Share Posted May 20, 2010 (edited) worth checking that the pivot points for the points and advance retard are greased. Edited May 20, 2010 by B40RT Quote Link to comment Share on other sites More sharing options...
max1956bikes Posted May 21, 2010 Report Share Posted May 21, 2010 set points to 12 thou,check timing Quote Link to comment Share on other sites More sharing options...
