mcman56 Posted May 24, 2010 Report Share Posted May 24, 2010 I'm putting together a simple C15 for trials. The existing carb is a monoblock 376/ 258 and under the dirt/ cobwebs appears serviceable. I believe but am not sure that it has a 1 1/16" choke. Should this be adequate for trials? If it makes a difference, the engine has the standard cam and 40-441 head. (big valve - 11/16" choke per the RR book) The other option at hand is a 22mm TLR200 carb but the mounting is different. Quote Link to comment Share on other sites More sharing options...
totalshell Posted May 24, 2010 Report Share Posted May 24, 2010 don morley lists for the c15T 7/8 Amal 140.main jet 25 pilot 375/4 throttle needle posn 3 needle jet 0.1055 Quote Link to comment Share on other sites More sharing options...
