Help Required /rear Wheel Spacers
p@ul250
Can any one out there help with a photo/description of the order,size of the spacers used on a model 49. I have just purchased a speedo drive replacement spacer from Bultaco UK that seams to be to long.
Thank you Swooshdave.I found the post(M80 Sherpa T rear wheel and axle) after looking at the photos you posted I can see that the spacer I have is to long as there is no room for the small spacer between the swinging arm and the brake plate.I will turn the big spacer down in the lathe in the morning.
Edited by paul250
